making your custom pitts exhaust???
richard armstrong
Postby richard armstrong » August 14th, 2014, 12:15 pm
hi all
looking for advice on making an exhaust for a 26cc engine side mounted pits style exhaust? i have a tight space to work with hence make it yourself, off the shelf pitts exhaust would do but i cannot find a side mount exhaust to fit the engine no choice but to make it
the original exhaust is a piece of dog poo,
i have paid £10 for some 50mm, and 19mm 16 gauge tube and sheet for end-plates, to make a barrel type exhaust i intend to use aluminium solder rods, but was thinking about silver solder?????
advice here please !
small tube for the baffle and possibly the exit as well?
the only thing is i need to make a 10mm exhaust stand off to match the opening not sure on technique but i could get this milled out of 10 mm flat bar or block?
advice here please?
barrie burton
Re: making your custom pitts exhaust???
Postby barrie burton » August 14th, 2014, 12:48 pm
Richard,a lot of shops,such as the pound shops etc,sell a range of stainless steel salt and pepper pots.This will give you a ready made canister,which can be silver soldered with pipe and the like.You will have to fill the letters P and S (usually perforated in the lid),with silver solder.Go to your local Wilkinsons or such like with a tape measure and also check the weight before buying,some are very heavy.
Best of luck Barrie B
richard armstrong
Postby richard armstrong » August 14th, 2014, 1:07 pm
nice idea thanks barry
keep them coming
did think o using a baked been can ???
Postby Rob Buckley » August 14th, 2014, 4:14 pm
Use the 'silencer' you've already got as a header, then a bit of pipe to one of these...
http://www.ebay.co.uk/itm/EHGINE-EXHAUST-FIT-BRIGGS-STRATTON-2HP-3HP-HORIZONTAL-/331265025361?pt=UK_Lawnmower_Parts_Accessories&hash=item4d20ef2551
...home in time for tea & medals.
richard armstrong
Postby richard armstrong » August 14th, 2014, 4:59 pm
Rob Buckley wrote:Use the 'silencer' you've already got as a header, then a bit of pipe to one of these...
thanks rob
