Postby Tinus Nielsen » August 22nd, 2014, 1:10 am
Looking good.
Have you given any thought to what size prop you will be running on the geared engines?
My own engine, fitted with the MR drive, spins a Menz 32x18 at 4250 rpm with a single DA-50 canister, and about 4500 rpm open exhaust. This is more or less comparable to what a Moki 250 radial does as far as I know.
But this also means that the prop is a little too small, as I would like the engine to spin about 6500 rpm on the ground, which translates to 3600 rpm on the prop. This should provide a dynamic engine which will not scream 10 K in level flight.
Not that this should hurt the engine in any way.
I have drawn up a 32,75x20 3-blade prop which I will try to fabricate on my cnc router. I have copied the airfoil thickness from a damaged Fiala wooden prop, and I have settled on a NACA 2414 for most of the blade length.
If my homemade prop does not perform as hoped I will most likely buy a Fiala 34x18 3-blade and cut this down until I reach the desired rpm.
I have attached a few pictures of the propeller as it is now. I´m still working on refining the transition from blade to hub, but this should work I hope.
The pictures also show the model that the engine will power. It´s a Yak-50, 1:3 scale, which means a span of 311 cm and a length of about 265 cm. At the moment it looks like I can keep it just under 25 kg fueled and ready for takeoff.
- Prop 1.jpg (51.98 KiB) Viewed 17122 times
- Prop 2.jpg (57.93 KiB) Viewed 17122 times
- Prop 3.jpg (45.06 KiB) Viewed 17122 times
- 7 resized.jpg (62.25 KiB) Viewed 17122 times
- 8 resized.jpg (33.78 KiB) Viewed 17122 times
- 9 resized.jpg (45.54 KiB) Viewed 17122 times
