Postby MalcolmDouglasPorter » April 28th, 2015, 8:45 am
Been busy since my last post. Had a scan at the hospital, a dental appointment, a day out in London on Saturday taking 'er indoors to the theatre (birthday treat), saw Billy Elliot which is highly recommended, especially for you Durham chaps, lunch out on Sunday and Monday getting over all that lot.
However did a little job on the Beverley yesterday, adjusted the lower connection arms of the two main assemblies. There was some flexing caused by a small gap where the arms slot onto the joining bar. I decided to remove this problem by angling the slots and gluing a wedge onto the bar. This causes the joint to tighten automatically as it is lowered. Although the upper arms are a good fit, I may do a similar thing there to ensure a tight fit. I may also fit some braces to the lower arms as well, this will not add any significant weight, but will ensure rigidity of the arms.
The model is now ready for East Kirkby. See you there?
- New wedge.
- P4270228.JPG (150.69 KiB) Viewed 11442 times
