Tony Nijhuis 1/6 Scale Lancaster
Craig Green
Re: Tony Nijhuis 1/6 Scale Lancaster
Postby Craig Green » February 5th, 2016, 12:44 am
Started working on the leading edge of the wing.
Applying strips on the top and bottom, then will add a complete sheet to cap it off. Figured I could save some wood.
Craig
Craig Green
Postby Craig Green » February 5th, 2016, 5:48 am
Glassed the outside of the flaps with 3/4 oz cloth, did this before they get beat up to much.
Craig
Craig Green
Postby Craig Green » February 7th, 2016, 9:59 pm
Finished up shaping the leading edge.
Have one side glassed.
Soon I will finally be able to cut the outer wing tip off, which will make it easier to work on.
Craig
Craig Green
Postby Craig Green » February 8th, 2016, 9:01 pm
Started working on the aileron covers to close the gap.
Made a sanding tool to remove material to the thickness of my glass.
Layed up two layers of 2oz cloth, think that's what it is.
Taped it in location, lifted it up applied medium CA, and glued it into location.
Next I will just fill the gap, and sand flush.
Craig
Andy ward
Postby Andy ward » February 8th, 2016, 9:06 pm
Fantastic job Craig coming on apace well done
can you show your hinging method for aileron and elevator cheers Andy
Craig Green
Postby Craig Green » February 9th, 2016, 4:02 am
Thanks Andy, I still have a long way to go, but slowly getting there.
Finished up the last of the aileron flanges (if that's what they are called) and am applying putty to smooth out.
This stage is almost complete.
Soon I will be able to separate the wings.
Craig
Craig Green
Postby Craig Green » February 9th, 2016, 4:06 am
Andy
I will dig up some pictures and explain my method.
Have not done the elevators yet, just the ailerons.
Craig
Craig Green
Postby Craig Green » February 9th, 2016, 4:19 am
Andy
I used a pin method for my hinges, I have seen several different ways to do this.
I used the yellow portion of a nyrod, which has an outside diameter of 1/8 inch.
The inner diameter takes a 1/16 inch pin, either steel or brass, your choice.
I made up hinges from popular wood, nothing to crazy, just Mede them ass the same. I did this for my flaps, so you can see the yellow nyrod.
What is nice about the Nyrod is the flexibility, so I have it travel the complete length of the surface that I need to move, makes inserting the pin easy and it always lines up. The brass pin is more flexible than steel.
Craig Green
Postby Craig Green » February 9th, 2016, 4:36 am
For the ailerons, I made up three hinges, and constructed the bottom portion of the aileron.
Then added a leading edge, and cut out the locations for the hing in the aileron.
Lined it up with the wing, cut slots in the trailing edge, and slid the male end into the trailing edge.
I could then adjust it for height so the top and bottom surface remains flush.
Then glued in the male end, and applied some triangle stock for added security.
I completely sheeted the aileron before it was attached.
Aileron placed against trailing edge
Used 1/8 brass tube to align all three hinges
Hinge
Hinge
Aileron hinge glued in
Bottom view of aileron attached, if you look at the top left corner you will see the nyrod that extends out to the wing tip
Craig Green
Postby Craig Green » February 9th, 2016, 4:38 am
Pictures of where the nyrod meets the aileron and where it comes out at the wing tip.
Craig Green
Postby Craig Green » February 9th, 2016, 4:42 am
A point on the actual hinges, for the control surface, you glue the complete length of nyrod in, then cut off the piece inside the two female pieces, to accept the male end, which remains in the wing.
You need to glue a small piece in the male end.
The rotation is smooth, no slop.
Craig
Andy ward
Postby Andy ward » February 9th, 2016, 9:38 pm
Thats fantastic Craig thank you for posting these much appreciated regards Andy
Craig Green
Postby Craig Green » February 10th, 2016, 5:10 am
Finished capping the top and bottom or the aileron bay, applied some 3/4 oz cloth to seal it.
Craig
Scott Crosby
Postby Scott Crosby » February 10th, 2016, 3:52 pm
Great to see you back at it Craig! looking good as usual!
Scott
Craig Green
Postby Craig Green » February 11th, 2016, 6:17 am
The fit of the ailerons is good, deflection up is good. Could not deflect down, the aileron horn is in the way and I need to cut out a pocket in the bottom cap strip for it, that can be done later.
Hope to separate the outer wing in a couple of days.
Craig
Craig Green
Postby Craig Green » February 13th, 2016, 11:24 pm
I now have a four piece wing.
Separated the wing with a hacksaw blade, turned out pretty good.
Lots of sanding and cleaning up to be done.
Craig
Craig Green
Postby Craig Green » February 14th, 2016, 12:47 am
Next thing to do is to fill the voids at the wing tube ends.
There may be a few voids which I will stuff in some cotton, then mix up some epoxy and fill the ends to secure it.
Craig
Craig Green
Postby Craig Green » February 15th, 2016, 12:24 am
Cleaned the edges up on both the inner and outer wings.
Sanded them smooth, and applied glass cloth to seal up the ends.
I still need to do the outer wings.
Craig
Craig Green
Postby Craig Green » February 16th, 2016, 12:03 am
Wing ends are sealed with glass cloth.
Ailerons will protrude when the wing is apart. I have lots of deflection up and down.
Also put some thin CA on the anti rotation dowels to strengthen them up.
Craig
Craig Green
Postby Craig Green » February 23rd, 2016, 5:28 am
More work completed on the wings.
Put some scotch tape on the inboard root, then a light coat of Vaseline as a release agent.
Mixed up some west systems and micro balloons and applied that to the root of the outer wing.
Users browsing this forum: No registered users and 30 guests
