correct plugs for weslake 342
Dave Collis 2296
Postby Dave Collis 2296 » November 14th, 2009, 1:41 pm
Good day gentlemen.
Can someone enlighten me as to the correct plugs for the above engine? When I acquired the engine, there were no plugs supplied.
Cheers, Dave.
Re: correct plugs for weslake 342
Postby Tony Collins 1073 » November 14th, 2009, 2:17 pm
Hi Dave, The original plug fitted to the 342 Weslake is the Bosch R10 resistor plug although similar types can be fitted.
The main consideration is the resistance reading through the plug which ideally for best interference control is a minimum of 8K ohms.
Give my regards to Mike Clemmens if you ever run into him.
Dave Collis 2296
Postby Dave Collis 2296 » November 14th, 2009, 9:13 pm
Thank you, Tony. As it happens I was talking to Mike on the phone a couple of months ago regarding props for my 3W 200.
Cheers, Dave.
Users browsing this forum: No registered users and 68 guests
