p47 air under cart advice
richard armstrong
Postby richard armstrong » February 15th, 2018, 7:40 pm
i have a large scale p47 with ray slack under-cart
i am in the process of putting a new air tanks and fittings,
i was wondering if it is worth putting in a air gauge to show tanks pressure at present the air tanks rides in the centre bubble of the wing with the fill value on the side, the gauge would sit in the cockpit
https://hobbyking.com/en_us/air-pressure-gauge.html
i know the best way is to keep it simple and avoid the points of failure
what would the best approach?
any suggestions would be helpful
Re: p47 air under cart advice
Postby Bob Thompson1894 » February 15th, 2018, 8:45 pm
Are you on commission for Hobbyking, Richard? Dont you have a pressure gauge on your pump? You will not see that dial as it flies by...
richard armstrong
Postby richard armstrong » February 15th, 2018, 9:04 pm
yes i have a gauge on the pump but i really was thinking about air leaks a gauge would show minor leaks on an unknown
stuart knowles 1611
Postby stuart knowles 1611 » February 15th, 2018, 9:31 pm
If possible, I would keep everything, Tank, valve and air control, into the wing. If its a split wing then there is/are only 1/2 connections to be made across the centre line. (depending on air up/down or air/spring) If a one piece wing then obviously no connections to be made on assembly at all.
If you have some components in the fus then the number of connections to be made on each assembly increases.
I don't use the gauge myself but if you can install one in the wing I can't see a problem really
Cary Bailey
Postby Cary Bailey » February 16th, 2018, 8:17 am
Richard, why bother with a gauge as Alan says you can't see it when it's flying! However you could go one step better and fit a pressure sensor that should the pressure fall below a certain level it activates the retract servo to operate the system to bring the undercarriage down! Then you know there's a leak!
richard armstrong
Postby richard armstrong » February 16th, 2018, 10:36 am
Cary Bailey wrote:Richard, why bother with a gauge as Alan says you can't see it when it's flying! However you could go one step better and fit a pressure sensor that should the pressure fall below a certain level it activates the retract servo to operate the system to bring the undercarriage down! Then you know there's a leak!
cary
i like the idea of the pressure sensor have you done this to any of the p51! and is there one available
richard armstrong
Postby richard armstrong » February 16th, 2018, 11:12 am
stuart knowles 1611 wrote:If possible, I would keep everything, Tank, valve and air control, into the wing. If its a split wing then there is/are only 1/2 connections to be made across the centre line. (depending on air up/down or air/spring) If a one piece wing then obviously no connections to be made on assembly at all.
one piece wing all air tanks and fittings are in the hump
all i was going to add a quick connector 3 way to the line in and a single pressure gauge
Cary Bailey
Postby Cary Bailey » February 16th, 2018, 1:09 pm
cary
Richard,
Yes
https://www.tamjets.com/gearfailsafe.php
