ALUMINIUM BAR
BRIAN RAWCLIFFE
ALUMINIUM BAR
Postby BRIAN RAWCLIFFE » February 23rd, 2011, 1:05 pm
Can anybody supply me with the following Aluminium bar, 22mm square x 50mm long if possible with a 16mm hole
bored through the length.Material only will be ok as if necessary i can do the bore myself.
I require two pieces for the job in hand,but if possible make it four then i will have two spares.Many thanks Brian..
John Evans
Re: ALUMINIUM BAR
Postby John Evans » February 23rd, 2011, 1:49 pm
Hi Brian
Try Forgale in heckmondwike. I have got all my plate and bar etc for making retracts. Near the Pondarosa not far from Morrisons.
john Evans
BRIAN RAWCLIFFE
Re: ALUMINIUM BAR
Postby BRIAN RAWCLIFFE » February 23rd, 2011, 3:31 pm
John many thanks Forgale have in stock 7/8" square bar which is 22.5mm so i can reduce it on my belt sander.
