20%VULCAN
Vince Raia
Re: 20%VULCAN
Postby Vince Raia » July 26th, 2011, 7:23 am
DAVE JOHNSON wrote:--think it will be late September before i start to crash on with it---DAVE
Dave, thanks for the update, (not a good choice of words in the quote :lol: ) looking forward to seeing this one finished and flying, trouble is, it will overshadow Andy's Victor :lol:
Without scrolling through the thread, what turbines will you be using?
cheers,
Vince.
Re: 20%VULCAN
Postby DAVE JOHNSON » July 26th, 2011, 7:51 am
Vince--yes you are right,not a good choice of words in our hobby---i am using 4---Merlins---2 out of the old Vulcan and 2 new ones---should have plenty of performance with those in--
Vince Raia
Re: 20%VULCAN
Postby Vince Raia » July 26th, 2011, 8:06 am
Yes good engines those Merlins, so I suppose you are retiring the old Vulcan?
Re: 20%VULCAN
Postby DAVE JOHNSON » July 26th, 2011, 8:23 am
Vince---i think at 18 years old,its is ready for retirement or a complete refurb,and once this new one is airborne i wont have time or incentive to work on the old one---i had intended retiring it at Rufforth last year,but the new one has taken me longer than expected so i have kept it going for another year--
Stuart Solomon
Re: 20%VULCAN
Postby Stuart Solomon » July 27th, 2011, 3:27 pm
Dave,re the horns, wait till you see the carbon one I have now. Could make them thicker if you want. ;-)
Re: 20%VULCAN
Postby DAVE JOHNSON » July 27th, 2011, 5:27 pm
Stu---thats the concern i had with the original ones you sent me--they need to be thicker --can you bring samples to Elvington
Re: 20%VULCAN
Postby DAVE JOHNSON » September 6th, 2011, 11:52 am
Now the show season is nearing the end,i decided to clear the workshop and start the final winter build of the Vulcan. the only parts of the airframe left to build are the control surfaces,so last night i built and fitted the first aileron and hinges etc,
2011-08-23_18.07.37FIRST AILERON.jpg (32.27 KiB) Viewed 13911 times
Re: 20%VULCAN
Postby DAVE JOHNSON » September 6th, 2011, 8:40 pm
After another good session this afternoon ,i have now completed the first aileron,and the second one ,and both servo boxes and servos installed
2011-08-25_21.29.032 ND AILERON.jpg (23.04 KiB) Viewed 13858 times
2011-08-25_21.28.53BOTH AILERONS.jpg (20.91 KiB) Viewed 13858 times
Re: 20%VULCAN
Postby DAVE JOHNSON » September 6th, 2011, 8:44 pm
The next stage now is to build the remaining two elevators for this wing---i intend finishing these and servo boxes before leaving for Catton this weekend,then the plan is to refit this wing to the fuselage and match up the under surface for final balsa sheeting
AndyHopwood
Re: 20%VULCAN
Postby AndyHopwood » September 8th, 2011, 11:40 am
That looks good. Few questions. Are the horns wood or plastic ? Can't see from here. Also what kind of hinges do u use ? Regards
Re: 20%VULCAN
Postby DAVE JOHNSON » September 8th, 2011, 12:19 pm
Andy--- they are very large and strong epoxy/carbon horns--- and i have used the large pin hinges extended with metal tubing---DAVE
AndyHopwood
Re: 20%VULCAN
Postby AndyHopwood » September 10th, 2011, 11:16 pm
Nice !! Horns home made ?? Any pics of the hinges for us to see ?
Re: 20%VULCAN
Postby DAVE JOHNSON » September 17th, 2011, 7:43 pm
Took a little longer than planned,but the 2 ailerons and 2 elevators on the first wing are now built and hinged etc,the rest of this last week has been spent making up extension leads and cutting out twin radio boxes ,and temp fitting receivers etc and linking up surfaces----the rest of the bottom sheeting has been glued in place [other then one last sheet where the metal fixing plates need bolting to main and sub spars],this wing has now been put to one side untill the retracts arrive from Alec at Chester---he tells me they should be with me in approx 10 days---
2011-09-16_10.32.471st wing under sheet.jpg (26.9 KiB) Viewed 13542 times
Re: 20%VULCAN
Postby DAVE JOHNSON » September 17th, 2011, 7:51 pm
As can be seen in the last piccy,6 satellite receivers have been spread around the wing---these have been mounted under little see thro covers so each can be checked for logging on etc,they have then been covered in masking tape ready for final sanding and filling etc,which will be done outside on benches in the garden when the weather permits.
Whilst waiting for the mains retracts,the second wing has been brought into the workshop---the top surface was filled and rubbed down earlier in the year for the display at Bradford,but the underside had been left with the cyprus stringers etc needing finishing,this was started today,and the first few sheets of balsa glued in place.With the poor forecast tommorrow,i will probably finish the section of covering around the wingtip/undercambered area,which is the awkward part--after this its much easier and straightforward--
2011-09-16_21.44.102nd wing sheet start.jpg (30.97 KiB) Viewed 13540 times
Re: 20%VULCAN
Postby DAVE JOHNSON » September 26th, 2011, 8:16 pm
Another weeks work has seen the awkward undercambered section sheeted--plus the 4 servo boxes cut out,and all the extension leads installed.Some of the satellites have been fitted as well as the sheeting goes on---in the piccy the first 3 satellites have been fitted ,with 3 more to install when more sheeting done.The mains retracts have just been picked up from Alec Griffiths at Chester[he advertises in the journal for metal work] and they look superb---a little more work to finish,but they are staying with me now to install so it can sit on its legs for the first time at Gaydon---the front leg will be with me in a couple of weeks to the same stage.
2011-09-23_20.35.27UNDER PLANKING.jpg (29.68 KiB) Viewed 13379 times
Re: 20%VULCAN
Postby DAVE JOHNSON » September 27th, 2011, 7:40 am
Last night,the first retract unit was test fitted,and some wood was shaved off to allow for clearance for retracting---the bearers will now be glued in place today so the rest of the surrounding balsa sheets can be fitted.
As can be seen in the piccies,the units are very close to completion,the scissor linkage needs fitting on the oleo,and several bolts etc need final fitting---the brakes are piped thro the alloy leg to save any pipes being on view and snagging on wheels
2011-09-26_20.06.001st retract fit.jpg (32.94 KiB) Viewed 13361 times
2011-09-26_20.06.38fisrt ret fit.jpg (35.65 KiB) Viewed 13361 times
1st leg retracted.jpg (33.37 KiB) Viewed 13361 times
Re: 20%VULCAN
Postby DAVE JOHNSON » September 29th, 2011, 9:37 pm
Another good few nights and the retract unit has now been test fitted and screwed in ready foor Gaydon---all the radio leads and satellite receivers have now been finished,and tonight the last sheet of balsa was glued in place.The leading edge was then rubbed down ready for the 1/2 "balsa to be added and rubbed into shape---this will be done tommorrow evening
2011-09-29_20.17.57last undersheet.jpg (21.62 KiB) Viewed 13282 times
Paul Holt
Re: 20%VULCAN
Postby Paul Holt » September 30th, 2011, 6:08 am
That undercarriage leg is a work of art!
Re: 20%VULCAN
Postby DAVE JOHNSON » October 8th, 2011, 7:48 pm
The last week has been spent rubbing down both wings---top and bottom---all sheeting now finished on these.
The retract tanks have been made up from metal gas canisters--each wing has 3 in parallel to give a good volume.The commercial valves were sourced thanks to many replies thro the forum---but in the end,LMA member Paul Hughes came to the recue with 3 perfect valves,which are being modified to fit as i type this thanks to Harold Dowbekin----the glasscloth and G4 pondsealer arrived today,so both wings have now been prepared for glassing---
2011-10-07_17.17.11wing rub down.jpg (28.75 KiB) Viewed 13069 times
2011-10-07_17.18.00wing rub down.jpg (25.38 KiB) Viewed 13069 times
Re: 20%VULCAN
Postby DAVE JOHNSON » October 9th, 2011, 8:52 pm
The rest of the wet Saturday afternoon was spent preparing the second wing for glassing
[attachment=1]2011-10-07_17.18.20latest.jpg[/attachme
