!/3 Pitts S2a Build
Stuart Palmer
Re: !/3 Pitts S2a Build
Postby Stuart Palmer » February 18th, 2011, 5:19 pm
Nice work, I'm building a 30% Pitts Special at the moment as a prototype or practice for a 50% version in the future.
The 50% version is on the CAD table at the moment but the 30% had some of it's paint this week. Must try to arrange some photos for on here.
Many thanks
Stuart
_________________________________________________________________________
http://www.thedebtexpert.co.uk
Dave Wood
Postby Dave Wood » February 27th, 2011, 7:37 pm
Hi Everyone,
I'm afraid I'd lost enthusiasm during the summer and had too many projects on the go.
The model is far from finished but I've just started back on the build, just joined the top wing panels. I'll put some pics up as soon as I get some worth uploading.
Still looking for a suitable engine though, I'd really like to put a twin up front to keep the vibration down to a minimum.
Dave.
Dave Wood. 3173
AKA Woodwings.
Dave Wood
Postby Dave Wood » March 18th, 2011, 8:28 pm
Some more pics.
Joining Upper Wing Panels
31. Joining Upper Wing Panels.jpg (51.55 KiB) Viewed 15500 times
32. Joining Upper Wing Panels.jpg (44.91 KiB) Viewed 15500 times
Adding the Cabane Strut Mounting Plates.
33. Cabane Strut Mounting Point Plates.jpg (48.91 KiB) Viewed 15500 times
34. Cabane Strut Mounting Point Plates.jpg (49.72 KiB) Viewed 15500 times
Upper Wing Centre Section Nearly Completed
35. Top Wing Centre Section nearly completed..jpg (44.41 KiB) Viewed 15500 times
Dave Wood. 3173
AKA Woodwings.
Dave Wood
Postby Dave Wood » March 18th, 2011, 8:35 pm
Still joining wing panels!
35a. Upper Wing Centre Section Top Sheeting. (Leading edge still to fit).jpg
Sheeting added to top of upper wing. (Leading edge still to fit)
35a. Upper Wing Centre Section Top Sheeting. (Leading edge still to fit).jpg (35.33 KiB) Viewed 15499 times
Joining Lower Wing Panels
36. Joining Lower Wing Panels.jpg (44.21 KiB) Viewed 15499 times
37. Joining Lower Wing Panels.jpg (48.43 KiB) Viewed 15499 times
Dave Wood. 3173
AKA Woodwings.
Richard Sullivan
Postby Richard Sullivan » March 19th, 2011, 3:23 pm
Looking good dave keep it up mate :) :)
Richard Sullivan LMA 3107
Dave Wood
Postby Dave Wood » March 31st, 2011, 5:09 pm
Today I've just been checking the fit of wings and tail feathers, checking alignment of wings to fuselage, tailplane to wings, and marking the position of the interplane strut half ribs so I can get on with finishing sheeting of top and bottom wings.
38. Assembly to Check Decalage, Position of Cabane and Interplane Struts..jpg
First fit assembly to check decalage.
38. Assembly to Check Decalage, Position of Cabane and Interplane Struts..jpg (41.65 KiB) Viewed 15367 times
Setting the Tailplane to 0 degrees using a Wixey Digital Angle Finder to use as a comparitor.
39. Setting Tailplane to 0.0 Degrees.jpg (43.62 KiB) Viewed 15367 times
40. Setting Tailplane to 0.0 Degrees.jpg (44.3 KiB) Viewed 15367 times
Comparing the upper wing incidence to the tailplane.
41. Checking Upper Wing Incidence Using Digital Angle Meter.jpg (43.18 KiB) Viewed 15367 times
42. Checking Upper Wing Incidence Using Digital Angle Meter.jpg (34.16 KiB) Viewed 15367 times
Dave Wood. 3173
AKA Woodwings.
Dave Wood
Postby Dave Wood » March 31st, 2011, 5:17 pm
Checking fit cont'd.
Comparing lower wing incidence to upper wing and tailplane.
43. Checking Lower Wing Incidence.jpg (37.24 KiB) Viewed 15367 times
Marking position of interplane strut half ribs.
44. Marking Position of Interplane Strut Half Ribs..jpg (43.1 KiB) Viewed 15367 times
45. Marking Position of Interplane Strut Half Ribs..jpg (41.62 KiB) Viewed 15367 times
46. Marking Position of Interplane Strut Half Ribs..jpg (42.47 KiB) Viewed 15367 times
Dave Wood. 3173
AKA Woodwings.
Postby stewart clifford » April 13th, 2011, 10:43 pm
Looking really good, I want one too. What a nice building board seems a shame to stick pins in it.
Dave Wood
Postby Dave Wood » May 1st, 2012, 5:50 pm
Enthused again, Flying wire - Landing wire wing fixings.
Landing Wire , Flying Wire Fixing.
47. Landing - Flying Wire Wing Plates Fitted. (Top view lower wing).jpg (39.44 KiB) Viewed 14569 times
48. Landing - Flying Wire Wing Plates Fitted. (Underside view lower wing).jpg
48. Landing - Flying Wire Wing Plates Fitted. (Underside view lower wing).jpg (42.72 KiB) Viewed 14569 times
Dave Wood. 3173
AKA Woodwings.
Dave Wood
Postby Dave Wood » May 1st, 2012, 6:01 pm
Interplane fixings Lower Wing.
49. Interplane Strut Fixing (Lower Wing).jpg (40.08 KiB) Viewed 14569 times
50. Interplane Strut Fixing (Lower Wing).jpg (39.22 KiB) Viewed 14569 times
Dave Wood. 3173
AKA Woodwings.
Dave Wood
Postby Dave Wood » June 26th, 2012, 10:16 pm
Fitting the Engine Bulkhead.
Engine Bulkhead
51. Engine Bulkhead Fitted.jpg (40.87 KiB) Viewed 14332 times
Bottom View of Bulkhead
52. Bottom View of Engine Bulkhead Fitting.jpg (38.03 KiB) Viewed 14332 times
Check fit of undercarriage
53. Checking Fit of Undercarriage..jpg (41.55 KiB) Viewed 14332 times
Dave Wood. 3173
AKA Woodwings.
paul smith
Postby paul smith » September 23rd, 2012, 7:58 pm
looking really nice ,very impressive build , keep it up :D
Dave Wood
Postby Dave Wood » June 15th, 2013, 6:07 pm
Making a start on the cowling, drawing is not very good for this as the parts are made for purchase as a plan pack.
Still here goes!
55. Assembled Profile Jig for Making a Pattern.jpg (37.22 KiB) Viewed 13428 times
56. Assembled Profile Jig for Making a Pattern.jpg (34.74 KiB) Viewed 13428 times
Dave Wood. 3173
AKA Woodwings.
Dave Wood
Postby Dave Wood » June 15th, 2013, 6:12 pm
57. Foam Block Rough Carved for Part of Cowl.jpg (37.86 KiB) Viewed 13428 times
59. Foam Blocks Rough Carved for Part of Cowl.jpg (35.85 KiB) Viewed 13428 times
60. Foam Blocks Rough Carved for Part of Cowl.jpg (34.31 KiB) Viewed 13428 times
Dave Wood. 3173
AKA Woodwings.
Dave Wood
Postby Dave Wood » June 21st, 2013, 6:39 pm
All the pieces of foam added and rough sanded to form the plug for a mould.
63. Rough sanded plug for mould.jpg (35.51 KiB) Viewed 13369 times
64. Rough sanded plug for mould.jpg (32.69 KiB) Viewed 13369 times
Dave Wood. 3173
AKA Woodwings.
Users browsing this forum: No registered users and 32 guests
