sd greenley
Re: sd greenley
Postby richard armstrong » April 27th, 2014, 8:31 am
the other issue is servos for elevator
on the plan is states 2 servos for elevator, is there a low profile servo that i could use and do u y lead them or mix them on 2 channels?
Re: sd greenley
Postby sean smith » April 27th, 2014, 9:11 am
I use two channels and mix my elevator servos on the TX that way if one fails i still have half an elevator working.
Re: sd greenley
Postby richard armstrong » April 27th, 2014, 10:53 am
agrreed 2 channels linked
as for the servos i was thing with of these 2
http://www.hobbyking.com/hobbyking/stor ... c_34g.html
or
Hitec HS-75BB low profile all working on 6v
decisions to make?????
Re: sd greenley
Postby sean smith » April 27th, 2014, 11:30 am
I think ether would be up to the job, the S3001 only have 3Kg at 6v. I use two 6v eneloop packs with a SM Services battery monitor.
Re: sd greenley
Postby richard armstrong » April 27th, 2014, 12:44 pm
decision made
for rudder 10kg server
elevators - 2 x Hitec HS-75BB low profile
aliron 2 x wing servo 5kg 6v
all working on 6v
Joshua Henderson
Re: sd greenley
Postby Joshua Henderson » April 27th, 2014, 5:30 pm
Sorted, number removed
Last edited by Joshua Henderson on April 27th, 2014, 7:11 pm, edited 1 time in total.
Re: sd greenley
Postby richard armstrong » April 27th, 2014, 6:35 pm
server taken josh deposit paid next week send details on PM
Joshua Henderson
Re: sd greenley
Postby Joshua Henderson » April 27th, 2014, 7:10 pm
Cheers, nice speaking to you.
If you need any help give me a call
Re: sd greenley
Postby John Greenfield » April 28th, 2014, 6:34 am
Richard
I think the Hi Tec 75 you are intending to use for the elevators is actually a retract servo and not proportional. If so it will be unsuitable.
I suggest a pair of Hi Tec 645's they will fit in the drawn positions without any problems. As one is mounted on top of the other and therefore the servo arms face opposite directions (one up and one down) you can join them with a "Y" lead and use 1 channel.
Re: sd greenley
Postby richard armstrong » April 28th, 2014, 12:20 pm
thanks john
i will be using a mixture of 645 and and some servo i paid deposit on from josh
Users browsing this forum: No registered users and 90 guests
