106 inch Hawker typhoon
chris willis
Re: 106 inch Hawker typhoon
Postby chris willis » November 2nd, 2009, 8:54 pm
Nice to see the interest, here is some rear end shots, they are hollowed where i can to keep the rear end weight to a minimum.
chris willis
Postby chris willis » November 10th, 2009, 6:34 pm
One outer wing panel and tip.
chris willis
Postby chris willis » November 11th, 2009, 6:56 pm
Today the cowling plug was finished and sent off to the fibreglass moulders, with a bit of luck we should see the finished cowls in a week or two.
chris willis
Postby chris willis » November 12th, 2009, 6:41 pm
today saw the wheel well coming to shape, the bearers are designed for a unitract unit, with a ply rib already fitted into wing to get the right shape and angle.
chris willis
Postby chris willis » November 14th, 2009, 5:20 pm
At last a stage where i wanted to be at, today i have joined the wings and now on the ailerons which are nearly finnished.
[URL=http://img121.imageshack.us/i/picture001w.jpg/]Image[/URL
Postby Mike Booth » November 15th, 2009, 6:19 pm
Looking great Chris, retract area looks spot on with two ribs picking up the bearers.
She's gona be good.
M
chris willis
Postby chris willis » November 21st, 2009, 3:39 pm
well the wings are nearly finished, as you can see flaps and ailerons are on, all servo boxes cut in and servo wires run. once retracts arrive i can box in the wheel wells. meantime i need to bandage outer panrls and fit controle horns.
Postby Mike Booth » November 23rd, 2009, 11:46 am
Flaps like barn doors, landings should be a peach.
M
Ken Bones
Postby Ken Bones » November 23rd, 2009, 1:59 pm
Hi all,
my Tiffy build is also progreesing well, with the model up on its wheels for the first time at the weekend.
Gave me a chance to weigh what i got so far as well, my build is as far as Chris's but i have the UC & wheels in place, so far it is only 12.5 lb.
So that allows for plenty of the lead that i am sure it will need!
Bonzey
chris willis
Postby chris willis » November 29th, 2009, 4:40 pm
The wing is now done, tonight i will put on the outer bandages then tomorrow i can start clothing.
Postby Mike Booth » November 30th, 2009, 8:54 pm
Looks good Chris, dont you just love the way that firewall is flush with the leading edge and there is about 4 metres sticking out at the back. :lol:
Ive just finished three 1/5 scale Napier sabre engines if you and Bonesy fancy one.
They come out at 4 kilos and will turn a scale prop so no worries balancing your models. :lol:
Mike.
chris willis
Postby chris willis » November 30th, 2009, 10:46 pm
Love one Mike. :D wouldn't that just be the Dogs, will give you a call soon so to all meet up before Xmas if poss
regards Chris
Postby Alan Cantwell 1131 » November 30th, 2009, 11:04 pm
What are you using for centre section spars? lot of foam missing, doesnt look to be a lot between the front of the wheel well, and the ply tongue plate?? are there spars running across, to take the pressure away from the areas that are cut out?
love the tiff, wish you well with it,hope you dont mind my quiry :)
chris willis
Postby chris willis » December 1st, 2009, 7:34 am
Hi Alan, yes this was a problem we picked up on, since the shot in the pic i have run a ply spar which runs behind tongue plate and cuts through slotting in with rib two, this modification will change slightly and should take place of tongue plate (which shall be a bit further forward) and then run through rib 1 & 2 and go into outer panel, the wing is about 5 inches thick and the well cuts in about 3 inches so there is a bit left there too, thanks for your interest
chris willis
Postby chris willis » December 3rd, 2009, 1:13 pm
The wing is glass clothed and in primer, this weekend i shall flat it down to get a nice finish and start on tail end bits
Postby Alan Cantwell 1131 » December 3rd, 2009, 6:24 pm
ON THE SUITE :o :shock: :o bet that was taken when the wife was out :D looking good, but how much weight will be up front?? orrid short nose on the Tiff, that napier sabre was a heavy brute
chris willis
Postby chris willis » December 3rd, 2009, 6:39 pm
You should have guessed i'm not married that's why it's on the soffa :lol: now my girlfriends house that would be another story :D I'm sure we will have to put lead up front but the tail has been made as light as poss to account for this.
chris willis
Postby chris willis » December 7th, 2009, 5:39 pm
Well as i have been rained off again have decided to paint under side of wing and hope to have fuz in primer next week.
chris willis
Postby chris willis » January 1st, 2010, 11:59 am
Well it's been a while, waiting for cowls and retracts and Christmas, i am now making the cowlings myself and here are some pictures of what stage i'm up to now, with a bit of luck i will press on and soon be done
Jon Horne
Postby Jon Horne » January 14th, 2010, 1:42 pm
Hi Chris
She's looking good, cant wait to see it in the air......what are you putting into the cowl to create the draft?
