Now onto the wing, the wing comes in 2 halves, with flap section cut out, ailerons cut out, tunnels for wires, and cuts for spars and ribs, over the next few weeks I will show the construction with the plug together spar.
- image.jpg (78.93 KiB) Viewed 15141 times
This shows the first spar being glued into place.
- image.jpg (71.21 KiB) Viewed 15141 times
Now glue down the outer rib, the one in my hand is just to show direction.
- image.jpg (73.77 KiB) Viewed 15141 times
Now a section of foam is re-fitted and the inner rib glued in, part of the foam will be cut away later for the wheel well and retract unit, seen here in the red hatching area where the retract rails will go.
