Postby Craig Green » February 9th, 2016, 4:19 am
Andy
I used a pin method for my hinges, I have seen several different ways to do this.
I used the yellow portion of a nyrod, which has an outside diameter of 1/8 inch.
The inner diameter takes a 1/16 inch pin, either steel or brass, your choice.
I made up hinges from popular wood, nothing to crazy, just Mede them ass the same. I did this for my flaps, so you can see the yellow nyrod.
What is nice about the Nyrod is the flexibility, so I have it travel the complete length of the surface that I need to move, makes inserting the pin easy and it always lines up. The brass pin is more flexible than steel.
- image.jpeg (102.57 KiB) Viewed 17752 times
- image.jpeg (95.85 KiB) Viewed 17752 times
