use weedeater featherlite 18cc as engine for spitfire
AndyHopwood
Postby AndyHopwood » August 13th, 2010, 6:28 pm
Hi guys I have an weedeater featherlite petrol trimmer 18cc and the pole is damaged and I kept the engine and thinking possible to convert into a petrol engine for my large spitfire it has a primer bulb the engine runs fine. my questions are is it is acceptable to use it as an engine when it has a primer bulb??
and since it is 18cc has it got enough power for (xmas Build Project) for 2011 year spitfire wingspan 89inch roughly 30-35lbs weight ? I can't work out the weight to power ratio i am too thick! hehe thanks guys :P
Andy
Matt Harrowven
Re: use weedeater featherlite 18cc as engine for spitfire
Postby Matt Harrowven » August 13th, 2010, 6:37 pm
18cc is way underpowered for a 89" spit, I would be looking for a 50cc engine.
LMA No. 3066
AndyHopwood
Postby AndyHopwood » August 13th, 2010, 8:52 pm
oh right that big then right let see if I can nick the moped bike that lad got across the road!!! thanks for the advice it is my first time with lma etc let say in cu i have 4 stroke 90 cu it that equal to roughly 1cc ?? so it looks like I need zeaoah engine then wooh mega deep pocket then mm i am going to have a serious thinking business!! cheers
Nick Reeves 3055
Postby Nick Reeves 3055 » August 13th, 2010, 8:57 pm
a .90 4st glow engine is roughtly 15cc but the power delivery is different to a 15cc petrol engine
Postby Mike Booth » September 11th, 2010, 5:55 pm
One word ......NO.
stuart cotgrove
Postby stuart cotgrove » September 12th, 2010, 7:04 am
Matt Harrowven wrote:18cc is way underpowered for a 89" spit, I would be looking for a 50cc engine.
Agree with Matt here, I had the DB Hurricane at 88" span with a Zenoah 38cc. That was Adequate but no way would I go smaller.
