LMA GENESIS. Inverted/upright Zenoh?
John Reynolds
Postby John Reynolds » August 1st, 2011, 6:08 am
A small matter; I am ready to think about the engine control run and have offered up the Zenoh 62 to the bulkhead. This leaves the plug, exhaust etc most exposed to a bad landing. Is there a reason why the motor cannot be set upright?
I am about to bend wire for the u/c and have 3/16th which I propose to double up for the main rear leg with 3/16th for the front section. Any advice as to suitabliity of the system please; I aim to incorporate a sprung spreader. If the wire is too flimsy I can always fit the part supplied.
Slater Reynolds.
Dave Collis 2296
Re: LMA GENESIS. Inverted/upright Zenoh?
Postby Dave Collis 2296 » August 1st, 2011, 1:14 pm
The engine doesn't care which way up it is. Most installations are inverted purely for packaging reasons and most a/market silencers are geared toward inverted mounting.
Dave.
John Reynolds
Postby John Reynolds » August 2nd, 2011, 8:34 pm
Dave, thanks for that, now I see from Toni Clark's instructions that it is best not to have the carb above the fuel tank so I could put the engine at 45deg which places the standard exhaust right in pilot's eye view! Thanks for the encouragement. Slater Reynolds.
Peter Clare
Postby Peter Clare » August 2nd, 2011, 10:38 pm
45 degrees from upright looks quite good and damage is less likely. My first and last ' incident ' with an inverted petrol engine - not a Zenoah or even a Zenoh - wiped out the spark plug , carb , high tension lead and several cooling fins. Best of luck. Peter Clare.
John Reynolds
Postby John Reynolds » August 3rd, 2011, 11:36 am
Peter, well, I am sorry you had that bump; at 45 deg the magneto seems to stay just inside the bottom of the fuselage but I'll wait a while in case there is reason for not trying it - unequal weight?
Thank you for good thoughts. Slater Reynolds
John Reynolds
Postby John Reynolds » August 6th, 2011, 6:20 pm
Thanks for the replies Dave & Peter; I will go for the 45 deg option, I can find quite a nice throttle cable run, Slater Reyolds.
