Retract filling valve
Mike altham
Postby Mike altham » January 12th, 2012, 12:46 pm
I am in need of two filling valves but I would like them to be the same as my first one.
It is from Unitracts and just utilises a standard tyre inflator adaptor.
Does anyone know where I cand get these adaptors so I can make my own fill valves
Mike
Re: Retract filling valve
Postby Rob Buckley » January 12th, 2012, 1:02 pm
Mike,
If it's just the standard car type stem, your local tyre fitting place should have a big plie of old ones they've taken out to sell people new ones.
I'm sure they'd let you have a couple
Rob
Mike altham
Postby Mike altham » January 12th, 2012, 3:08 pm
Hi mate
Do they have a threaded end on the other end as I would need to screw it into a ali block
Mike
John Rickett
Postby John Rickett » January 12th, 2012, 5:32 pm
Mike,
The Unitract fittings have a festo connector at one end and a Schraeder fitting at the other. By using the supplied nuts the fitting can be fixed to a ply or aluminium plate. Unitracts is still in business, albeit on reduced hours, so couldn't you get the proper things and save yourself some trouble?
John Rickett
Postby Rob Buckley » January 12th, 2012, 6:28 pm
As I recall, the tyre valves are brass & threaded along their whole length once the moulded rubber is cut off.
I was going to suggest Unitracts, but I though that was a bit obvious & would be bordering on facetious!
Phil Clarke at Fighteraces sells them too.
John Rickett
Postby John Rickett » January 12th, 2012, 8:31 pm
Rob,
When you get to my age, stating the obvious and being facetious bcome natural!
Postby Rob Buckley » January 12th, 2012, 9:44 pm
Saying nuffink... 8-)
Martin Waller
Postby Martin Waller » January 30th, 2012, 11:27 am
I have recently bought one from Unitracts.
Martin 1237
Martin Waller
Postby Martin Waller » January 30th, 2012, 11:28 am
Martin 1237
Mike altham
Postby Mike altham » January 30th, 2012, 11:07 pm
Hi guys
Got two from Phil at fighter aces.
Removed the small nipple and the inner of the valve tapped the end 5 mm and fitted a 4 mm festo fitting.
