Postby David Jones » August 7th, 2012, 10:32 am
Next up was the wings, which are really in three sections, a removable outer panel which is built at the same time as the mid panel, which in turn is later joined to the centre section forming part of the fuselage. These panels were built as per the plan, the only modifications I did was in the system for retaining the outer panel. The plan shows a retaining bolt which screws into a block in the joiner tube, and which is accessed via the wheel well. I wasn’t keen on this method, so I pinched an idea from the Zirolli Mitchell build, and made up a ply tongue that slides into the outer section, and is retained by a 4mm bolt, accessed from underneath the wing.
One method of forming the wheel wells is by utilising foam and lining it with 1/16” balsa. I decided to make up formers out of 1/ 4” balsa and made the walls up out of 1/32” rolled ply. With the top sheeting completed, the wings were then put to one side.
- Vampire build history 015 (Small).jpg (50.7 KiB) Viewed 22552 times
- Vampire build history 021 (Small).jpg (33.21 KiB) Viewed 22552 times
- Vampire build history 022 (Small).jpg (34.8 KiB) Viewed 22552 times
- Vampire build history 024 (Small).jpg (41.81 KiB) Viewed 22552 times
