G4 and Elapor foam.
G4 and Elapor foam.
Postby Tony Collins 1073 » March 11th, 2015, 10:12 pm
Hi all. I am in the process of building a foamy made from Elapor :lol: and I would like a decent paint job finish.
As Elapor is fussy about what it adheres to so I have read, I need to prepare a decent surface that will accept paint without any problems. I am considering G4 and would like to know if is this the way to go.
As it is a a reasonably large foamy it will be able to carry a little extra weight with it being a problem.
Any help and guidance would be greatly appreciated.
Cheers Tony.
Steve Mansell
Re: G4 and Elapor foam.
Postby Steve Mansell » March 12th, 2015, 12:49 am
I know most epoxy dosn't work on Elapor, but Multiplex do a range of paints specifically for it.
http://www.4-max.co.uk/multiplex-paint.htm
Postby Tony Collins 1073 » March 12th, 2015, 1:34 am
Hi Steve, If I paint straight onto the foam even if I flatten it a bit I am not going to get a good smooth finish. I have to prepare it with something . that is why I wondered if G4 might do the job. That isn't an epoxy is it.
Tony.
Postby John Greenfield » March 12th, 2015, 7:15 am
Do a test first as G4 melts normal types of foam and may do the same to Elapor
Postby stuart knowles 1611 » March 12th, 2015, 8:33 am
http://www.modelflying.co.uk/forums/postings.asp?th=100000&p=5
Take a look at the finish that these guys achieve on Depron, Not an area I know anything about but with their ideas thransfer to your situation?
just a thought
stu k
Postby Barrie King » March 12th, 2015, 3:01 pm
Hi Tony,
Take a look at Foam Armour from Delux Materials might do the job?
Barrie
Nigel Cox
Postby Nigel Cox » March 12th, 2015, 7:13 pm
Postby Tony Collins 1073 » March 12th, 2015, 8:20 pm
Thanks to you all for your suggestions. This forum is better than google if you need some good advice from knowledgeable lads.
As I need a really good surface prepared before I use any primer or paint I think I'll give the
Foam armour a try. Cheers Barrie.
Tony.
Nigel Cox
Postby Nigel Cox » March 12th, 2015, 8:57 pm
That "Foam Armour" doesn't set hard it remains "rubber" like and didn't seem to adhere too well to the Elapor
Postby Tony Collins 1073 » March 13th, 2015, 8:58 am
Thanks for that Nigel. So the search continues.
Tony.
Users browsing this forum: No registered users and 69 guests
