Postby david clarke » June 3rd, 2013, 8:01 pm
Cracked on since last post,all servos now fitted,pull pull wires all done on rudder and elevators,just waiting for some fittings to arrive to finish ailerons.Also made a duct to direct the air over the cylinder,also modified the exhaust to suit.Weighed it again today with everything in it,it tipped the scales at 37.5 lb,CG is spot on but i will add just a tad of nose weight just to be on the safe side,now waiting for the fittings and the 30x10 to arrive and i can go and play.
Cheers,Dave.
- 001.JPG (62.51 KiB) Viewed 10266 times
- 003.JPG (65.35 KiB) Viewed 10266 times
- 005.JPG (37.96 KiB) Viewed 10266 times
- 007.JPG (31.16 KiB) Viewed 10266 times
- 008.JPG (33.51 KiB) Viewed 10266 times
- 010.JPG (50.07 KiB) Viewed 10266 times
- 012.JPG (45.16 KiB) Viewed 10266 times
- 013.JPG (43.13 KiB) Viewed 10266 times
- 020.JPG (54.83 KiB) Viewed 10266 times
