The peoples projects
Re: The peoples projects
Postby Phil Clark » June 15th, 2013, 9:11 pm
The 4 piece tail wheel doors are to be mechanically driven by the retracting tail wheel.
Here they are part way through sorting the linkages out.
Postby Phil Clark » June 21st, 2013, 6:37 pm
After a lot of trial, fit, adjust........the mechanical tail wheel doors on the Corsair are all done & working a treat. As the wheel retracts the final 1/2" or so, it hits a spring loaded hinged plate which is connected to the door bell cranks which drag the doors shut. As the plate is spring loaded, as the wheel extends and releases it's upward pressure on the plate, the doors spring open and are held open by spring tension.
The wings are also painted (Warbirdcolors US Sea Blue) and markings are on. Paint masks for Flightline Graphics.
Cockpit interior next.......
Postby Phil Clark » June 28th, 2013, 9:04 pm
Corsair cockpit interior......plenty of artistic licence here as all I have is a handful of photos/artists impressions. The left side of the interior is pretty much complete & ready for paint. The side panel and console is from styrene faced 1/16" balsa, all the bits & pieces have been made from a combination of chemiwood, styrene sheet & tube, litho etc........
Nothing is finally bonded together here.......it's just resting together with a few dots of double sided tape here and there. The right hand side isn't far behind...............
dave tilbury
Postby dave tilbury » July 3rd, 2013, 9:52 pm
just finishing an old project.......need to add some more bits and fly!
here's another just finished........already test flown without colour scheme......on 2 6cell 5000 and 90mm EDF units......goes really well
Mike Booth
Postby Mike Booth » July 3rd, 2013, 10:19 pm
Cracking models Gromit.
Superb. The 262 is my second fave aircraft of all time.
How good it is to see sorted, modern examples of this incredible machine.
I had three in succession in the 1980s. Very successful hand launch single, followed by two twins with .40 glows.
As there was no propwash over the tail, flight control at low ish speed was akin to balancing a ping pong ball on a football.
Oh happy days.
Postby Phil Clark » July 15th, 2013, 11:11 pm
Cockpit interior on the Corsair now complete.....just the canopy to fix in place and the fuz is ready for it's blue. As can be seen, the cockpit was built section by section & complete finished panels were bonded in section by section.......far easier this way than trying to work bit by bit through a small opening.
David Brown
Postby David Brown » July 16th, 2013, 4:55 am
Fantastic Phil, wish I had the time ,patience & skill to do what you do.
Mike Booth
Postby Mike Booth » July 18th, 2013, 2:46 pm
Piloted by John Wayne no less. Who also flew Sabres in Korea apparently ..!
Denis Brown
Postby Denis Brown » July 18th, 2013, 5:02 pm
What film was that in then Mr.Booth :mrgreen:
paul cartwright
Postby paul cartwright » July 19th, 2013, 4:37 pm
The film is called jet pilot. I have a copy on DVD if you want it!
dave tilbury
Postby dave tilbury » July 25th, 2013, 7:43 am
test flown last night........1/4 scale....
Postby stewart clifford » July 25th, 2013, 8:09 am
Very nice DVIII Dave.
dave tilbury
Postby dave tilbury » July 25th, 2013, 12:14 pm
Thanks Stewart
Postby Phil Clark » July 25th, 2013, 10:04 pm
Paintwork complete.........time to start dirtying up a bit with a light 'wash'.......looks very bold here but it will dull down nicely with the application of the final satin clear coat.
Paul Williams
Postby Paul Williams » July 26th, 2013, 6:48 am
Superb detail work Phil.
sean smith
Postby sean smith » August 3rd, 2013, 10:37 am
Hi all,
A couple of up-date pictures of the Mosquito build so far.
Sean.
Postby Phil Clark » August 12th, 2013, 9:13 pm
Almost there with the Corsair.........just the final clear coat to do then it's a systems re-installation job.
Steve Rickett 2333
Postby Steve Rickett 2333 » August 16th, 2013, 8:19 am
Very slow progress on the Boston, but it is still moving. Just about ready for glassing and final finishing.....Will it get done over the winter?
Postby Phil Clark » September 11th, 2013, 9:49 pm
Pretty much done on the Corsair now......initial CG check & engine run carried out yesterday, should have the last few jobs tied up by the end of the week.
John Rickett
Postby John Rickett » September 22nd, 2013, 8:34 am
2 years in the building and its reached the almost-ready-to-fly stage.
I don't know how ARTF manufacturers do it for the money, my worth seems to be about £0.05p per hour!
Users browsing this forum: No registered users and 18 guests
