Geoff McVey wrote:I have a few questions if I may.
1... Where is the best place to buy a Zenoha 62cc engine from, plus fuel tank?
2... What type and size of prop would you select for the Zenoha 62cc?
3... What type and size of servos would you select?
4... Need to buy a new transmitter, any suggestions here would help?
5... Where would you buy an U/C for the Greenley?
6... Would either 88" or 100" span Greenley be good or should I stick with the 88" version, is there much difference between the two?
7... Would you suggest to build the wing as one piece or build it as two?
8... Undecided yet to build the wing as built up or foam, any suggestions here from what people have built so far?
Alan Cantwell 1131 wrote:a lot of us are going away from nimhs, even at sub c size, and going onto ABC life batteries
Users browsing this forum: No registered users and 119 guests
