First Large Model
Re: First Large Model
Postby Alan Cantwell 1131 » June 23rd, 2013, 8:23 am
With the greenly being able to use a plethoria of differant engines, for various tasks, i think you have to look to the future, and what airframes will be taking your fancy, you can always throttle back, but if the powers not there, your limited,
The Zenoahs, being old tech (but still the best out there for plodability) take some cowling in, ok for the greenly, but can be difficult to get in a tight cowl, they are tough, reliable, and VERY long lasting, and these days, the motors come in electronic ignition, so starting is no probs for the owner, But, there are more powerfull out there, ive just ordered a DLE 34 CC motor, angled plug, rear intake, rear exhaust, its got all the attributes for a cowled install, i still love my zenoahs, but there is now much more choice, it needs homework, as for the 45 V 62, they are the same physical size, i would go for the 62, but rev limit it, until you are used to the power
sean smith
Postby sean smith » June 23rd, 2013, 12:27 pm
Hi Geoff,
PM sent.
Sean.
Geoff McVey
Postby Geoff McVey » June 24th, 2013, 8:29 am
Building the Greenley with the 88" wingspan would it be a good choice putting a Zenoha 45cc engine up front, what prop would you fit with an engine of this size, and would it be a good choice to add flaps as well?
Geoff McVey
Postby Geoff McVey » June 24th, 2013, 3:03 pm
Hi Rob,
How good are the A123 batteries and why? And where can you get them from?
Geoff
Geoff McVey
Postby Geoff McVey » June 24th, 2013, 3:08 pm
Alan Cantwell 1131 wrote:With the greenly being able to use a plethoria of differant engines, for various tasks, i think you have to look to the future, and what airframes will be taking your fancy, you can always throttle back, but if the powers not there, your limited,
Hi Alan,
Your post is a great help indeed, and of course a little homework to do.
Thank you
Geoff
Postby Rob Buckley » June 24th, 2013, 5:22 pm
Geoff McVey wrote:Hi Rob,
Geoff
Geoff,
Simply they're robust lithium batteries that have the benefits of lipo cells & the added advantage of needing no voltage regulation, with the robustness of nicads.
Have a read of these for some more info, and a UK supplier picked at random...As always with these kinds of things, Google is your friend...
http://www.hangtimes.com/a123_batteries_for_giants_faq.html
http://www.electricwingman.com/2s-a123-battery-packs.aspx
Geoff McVey
Postby Geoff McVey » June 24th, 2013, 9:30 pm
Rob,
Thank you for the two web links, will take a look and have a good read.
Geoff
sean smith
Postby sean smith » June 24th, 2013, 9:35 pm
Can you recommend a decent charger for the A123 battery packs?
Geoff McVey
Postby Geoff McVey » June 27th, 2013, 7:15 am
Are the Greenley plans also available in .dwg format that you can open in CAD software?
Postby John Greenfield » June 28th, 2013, 6:45 am
Geoff
The Greenley plans are not available for general release in .dwg format as in the past people have then modified the drawing and passed it on as a genuine Greenley.
The .pdf drawings are correctly sized and will print out correctly as they are.
If you contact me and explain why you want a .dwg drawing we can have a discussion and I may release a file to you.
01923 857009 after 7.30pm
Geoff McVey
Postby Geoff McVey » June 28th, 2013, 4:38 pm
John,
Have sent you a PM, I have no intention of modifying your plan, and will be building direct from .pdf plans that are available from the Ghost Squadron website.
Geoff
Geoff McVey
Postby Geoff McVey » June 28th, 2013, 4:51 pm
Once building starts would like to post some photos to show the progression and ask any questions that I may have, when posting or attaching photos in a message, are there any limitations on the size of the photo in pixels and size of the file itself?
Geoff McVey
Postby Geoff McVey » July 10th, 2013, 2:13 pm
PDF plans downloaded and printed out on A4 sheets, now being tapped together in suitable sizes, i.e. tailplane, fin, formers, fuselage, wings etc.
Postby John Greenfield » July 11th, 2013, 6:44 am
Good luck with the build, looking forward to your progress reports.
Geoff McVey
Postby Geoff McVey » July 11th, 2013, 9:54 pm
John,
Thank you, will post regular updates and progress reports.
Geoff
Users browsing this forum: No registered users and 87 guests
