AutoCAD HELP please
richard armstrong
AutoCAD HELP please
Postby richard armstrong » January 5th, 2015, 5:10 pm
I would like help scaling
i want to trace a plan i have got and rescale
really need help setting up design/page templates? for different paper size & printer etc
the plan is 1/4 scale and i wish rescale using the auto cad scaler, what i want to know
do you have to set up a template page first at 1.1, or set up the page template @ 1.4 scale i get confused when trying to sort this out,
is someone can teach me the process, i can set up a remote session using team viewer
any help appreciated and thanks in advance
Re: AutoCAD HELP please
Postby Rob Buckley » January 6th, 2015, 8:34 am
I've not used AUtocad for a year or three...which version are you using?
Most important thing is to always draw at full size.
If you've imported a 1/4 scale drawing, scale it up to the size you need so that it's full size.
To print, what I would do is draw a full size rectangle the size of your printed page (A4, A3, A2 etc) then copy the rectangle so that it covers all the areas of the drawing that you want to print.
Then when you print a selection, snap to each page-sized rectangle & it will print that chunk of the drawing at the right size. Tape all the bits together, job done.
Stuart Solomon
Postby Stuart Solomon » January 7th, 2015, 11:34 am
Do your drawing at the size you want it then go to printer and select actual size, the printer will then tile the drawing and add registration marks for joining, this is of course if your printer only prints smaller than your drawing. Find someone with an AO printer or take your drawing on a cd to a digital print office, not expensive ;-)
richard armstrong
Postby richard armstrong » January 8th, 2015, 12:05 pm
hi guys i have access to a large format printer up to 48 inches wide my version oFis autocad 2013 full 3d versioni need to set up templates for other things as well like page sizes print sizes extended printing extended on the roll stuff you name it i'll try and do it i just need someone to remote on and help me with the initial setup or take me to a website 4 template setup any help will be appreciated once someone shows me how to set up one template i can do the rest myself thanks in advance speak soon
rob buckley can you give me a ring please mate
richard armstrong
Postby richard armstrong » January 17th, 2015, 4:40 pm
sorted thanks chaps
