Postby David Brown » December 14th, 2014, 1:38 pm
Hi karl, I will try my best but I have decided to build another plane at the same time. It is a 1/3.5 bf 109 Buchon, I have started the drawings and it will take the same power plant as the P-40 using the 4 blade prop I have test run. Meanwhile the P-40 is coming along, I have completed the clean up of the former's and tack glued it all together along with dry fitting of the strips to check the outer profile. A little bit to do hear moving a few slots and altering the profiles but not as bad as I thought it might be.
- DSCF1369.JPG (158.16 KiB) Viewed 10367 times
- DSCF1370.JPG (174.61 KiB) Viewed 10367 times
