hi all i have to drill out several props for a DA50 Rear
has anyone got a prop drill guide they would like to sell or lend me
if you have please get in touch
ric
Alan Cantwell 1131 wrote:Did you use a pillar drill, or a hand held, and did you put a bolt in the first hole drilled, to stop the jig moving, check the pitch circle diam with the prop washer, ,
Dave Wilshere wrote:Well maybe it was a 'poor'quality DLE jig as I have both genuine DA and DLE (from MacGregor) jigs and If I hold them together they are identical. I've sold lots of DLE type to DA customers with no comment.
Pillar drill is only OK if the bed is flat and 90 degrees to the drill. Props need to be supported on the hub to sit square, so props the TE of the blade is below the hub...
Users browsing this forum: Bing [Bot] and 13 guests
