Meister P47D Refurbishment
Re: Meister P47D Refurbishment
Postby stewart clifford » February 14th, 2011, 10:25 pm
I've got a few pics which I'm waiting for "her indoors" to resize for this site. The Whole model was taken back to the glass, the tailwheel doors will be re-made whilst the edges have been repaired. Steve just wants it re-painted so there won't be any flashy new parts other than the new cowl and gear doors all round.
Postby stewart clifford » February 15th, 2011, 11:17 pm
This is the front end after the grey paint was applied yesterday.
Feb 11 005.jpg (26.23 KiB) Viewed 14106 times
Feb 11 007.jpg (24.53 KiB) Viewed 14106 times
Postby stewart clifford » February 15th, 2011, 11:26 pm
The camo pattern is very unusual and we don't have many good pictures of the original fullsize aircraft, there are a few useable pictures of the left hand side but not much of the right. To make it even harder the restored airworthy P47 in the states isn't very accurate either, so I've had to use a bit of artistic license and a bit of both old and new. The wings on the modern one show the green as splodges wheras on the wartime aircraft they appear to be a mixture of splodges and thin strips.
The paint in the pictures is only a few light coats and is still in the process of drying hence it's appearance.
Feb 11 011.jpg (23.87 KiB) Viewed 14106 times
Mike Booth
Postby Mike Booth » February 15th, 2011, 11:37 pm
Stu check out www.hyperscale.com and look at all the P47 kits they have this scheme on there.
Postby stewart clifford » February 15th, 2011, 11:46 pm
Yeah been on there, theres tons of them. Don't think we will ever find all round pictures of the original aircraft though, Who's gonna know it's not quite right?
Jason Webb
Postby Jason Webb » February 16th, 2011, 12:15 pm
Stewart,
You might want to have a quick look at the following Pathe News clip
http://www.britishpathe.com/record.php?id=46331
Left side http://www.littlefriends.co.uk/gallery. ... rchString=
Right side http://www.littlefriends.co.uk/gallery. ... rchString=
Then you may also want to have a look at this thread also:
http://p47.kitmaker.net/modules.php?op= ... 529&page=1
Hope this helps
Jason
"It's true hard work never killed anybody, but I figure, why take the chance?"
Ronald Reagan
Postby stewart clifford » February 16th, 2011, 10:16 pm
Thanks for that Jason, thats shed some light on things, what becomes apparent is that the aircraft was repainted with a different camo scheme causing some confusion when we've compared photo's of the modern and old. Despite the gear doors being bare metal the underside seems to still be light grey, certainly the starboard wing will have been grey as it retains it's invasion markings.
Feb 11 016.jpg (30.2 KiB) Viewed 14045 times
Gregg Veasey
Postby Gregg Veasey » February 16th, 2011, 11:06 pm
Looking good Stewart.
I'm still waiting for an opportunity to get primer on mine. I have done some more work on the hatch though.
The air valve complete with large washer slides out of its mount when pumping up the system meaning the magnet couldn't go in that corner or the middle. So as you see in the pic its mounted in the other corner. The two holes will house the toggles switches and the slots will house the charge sockets. The door has been faced with soft balsa so that I can sand it to the shape of the fuz before adding thin lithoplate with a slight overlap to disguise the gap.
A small part of the model but one that I like to do......and better on each model
Last edited by Gregg Veasey on February 16th, 2011, 11:16 pm, edited 1 time in total.
Mike Booth
Postby Mike Booth » February 16th, 2011, 11:16 pm
I love glue Stu :lol: Im going to have that hatch set up on my new Spit.
Nice one Gregg.
M
Gregg Veasey
Postby Gregg Veasey » February 16th, 2011, 11:21 pm
stewart clifford wrote:This is the front end after the grey paint was applied yesterday.
Looks like those outlets need some bling!!!
Postby stewart clifford » February 17th, 2011, 6:50 pm
Not sure about bling, thinking of making it all dirty an 'orrible especially as people are getting upset about the squeeky clean Spitfire.
I finished the camo on the fuz today, I'm pretty inmpressed with the paint should be able to crack on with the markings tomorrow.
Ken Bones
Postby Ken Bones » February 17th, 2011, 6:54 pm
No panal lines, no rivits, no access panals. A good opertunity missed I say. Not Fighter Boys fault though!
Bonzey
chris willis
Postby chris willis » February 17th, 2011, 7:06 pm
That's squeaky clean :D
Gregg Veasey
Postby Gregg Veasey » February 17th, 2011, 7:28 pm
stewart clifford wrote:Not sure about bling,
just meant using my dads idea that I've done on mine
Gregg Veasey
Postby Gregg Veasey » February 19th, 2011, 11:50 pm
good old daddy primed the bolt yesterday and then filled the blemishes. So, my next job is to rub it all down before it gets another blow over before doing the panel lines and rivets
Postby stewart clifford » February 20th, 2011, 9:18 pm
Still just slightly ahead of you, I got the camo finished on the fuselage and started spraying the serial numbers and kill markings today.
Gregg Veasey
Postby Gregg Veasey » February 20th, 2011, 9:24 pm
Pics Stew?
You are well ahead of me then as I have the panel lines and rivets to do before final spraying.
Postby stewart clifford » February 20th, 2011, 9:28 pm
Pics would be pointless at the mo as she's all wrapped up in newspaper
Last edited by stewart clifford on March 1st, 2011, 8:05 am, edited 1 time in total.
Gregg Veasey
Postby Gregg Veasey » February 28th, 2011, 10:30 pm
My bolt is all primed, filled, rubbed down...repeat umpteen times!!!!!
Am now waiting for a delivery of lining tape to continue its progress!
Postby stewart clifford » March 1st, 2011, 8:07 am
Whats the Spitfire in the corner Gregg?
Users browsing this forum: No registered users and 29 guests
