The peoples projects
ian redshaw
Re: The peoples projects
Postby ian redshaw » April 7th, 2013, 9:51 pm
Full size Cri Cri?
Ian.
Postby Phil Clark » April 7th, 2013, 10:46 pm
Piper Tomahawk?
Dave Hayfield
Postby Dave Hayfield » April 7th, 2013, 11:09 pm
Give Ian a cigar! Not full size, just 3/4 which will fit into the car by removing the tail section.
Thanet Model Flying Club
LMA 520
dave tilbury
Postby dave tilbury » April 25th, 2013, 7:41 am
airworld Me 262........just needs some minor things doing to it before maiden.....
nice kit goes together really well
[imghttp://www.rcscalebuilder.com/forum/uploads/tigermoth/images/2013-04-21_045536_m_P1050524.jpg][/img]
Postby Phil Clark » April 25th, 2013, 9:33 pm
Ziroli Corsair still progressing in the back ground.........surface detail on the wings is all complete, a few small jobs to do on the fuz and it's up for the same treatment.
david clarke
Postby david clarke » April 26th, 2013, 5:39 pm
Very nice Phil,look forward to seeing the finished article.Been busy myself as usual,bought this Comp arf hawk for myself but have now decided to sell it.It came to me in the Display colour scheme with an awful lot of hangar rash some really bad,so the decision was made to totally refurb and repaint.The majority of the uc doors were also missing.The scheme chosen is to comemorate the 70th anniversery of the Spitfire,after looking at many schemes this one really jumped out at me.Now nearing completion it will be up for sale,i have all the maintanance marking from tailormade decals to fit,it is full of JR servos and carf retracts.
Cheers,Dave.
http://photos.plane-mad.com/8/large/8864.jpg
Postby Phil Clark » May 3rd, 2013, 10:26 pm
Painting started on the Corsair.
Warbirdcolors 'US Sea Blue' thinned 25% with concentrated auto screen wash, applied with 0.6mm HVLP Iwata mini spray gun. 3 light coats giving excellent coverage with minimal paint used so the flush surface detail remains prominent so a wash should bring it all out later in the finishing process.
Paul Williams
Postby Paul Williams » May 4th, 2013, 3:25 pm
Thought I would add a couple of photos of my latest build, Meister Corsair, but not blue or grey, Lucky Gallon was a 1946 Reno Race.
Postby sean smith » May 5th, 2013, 8:00 am
Starting to look a bit more like a Mosquito now.
Sean.
Postby Phil Clark » May 9th, 2013, 9:00 pm
More little rings appearing on the Corsair fuz :ugeek: ..............
Ken Bones
Postby Ken Bones » May 10th, 2013, 7:45 am
Paul Williams wrote:Thought I would add a couple of photos of my latest build, Meister Corsair, but not blue or grey, Lucky Gallon was a 1946 Reno Race.
Nice one Paul.
For a first attempt at panal lines, rivets, dirt etc you have made a cracking job.
A brave move doing a warbird as a racer, perhaps some more will follow?
Bonzey
RAY PETERS
Postby RAY PETERS » May 20th, 2013, 5:17 pm
Does anyone have some pics and details of John Braithwaites big ZERO that under construction. Ozy ;)
Aaron norman
Postby Aaron norman » May 21st, 2013, 8:09 am
Getting the with the la7 got the finally coat of primer on today then started on the Riverts hope to get the rest of the fuz done buy the end off the week the onto the wing
Aaron
Postby sean smith » June 7th, 2013, 10:16 am
OPINIONS PLEASE. Do you think the mini servo with 3Kg of torque will be man enough to open and close the bomb doors on my Mosquito? As can be seen from the photo's the doors open beyond the fuselage sides and you can't get a straight run at the door.
Postby David Brown » June 7th, 2013, 2:35 pm
Hi Sean, try reversing your horn you are using to pull the door closed with. As you close the door the leverage gets less the way you have it, when it needs to be at its strongest, use all of the servo travel to get best out of your linkage and servo, keeping doors closed is harder than opening them due to air pressure in the fuzz when flying.
all the best Dave
Postby sean smith » June 7th, 2013, 4:23 pm
Hi David,
Thanks for the reply, i'll try re configuring things and see how it works out. I may try air rams but they may get in the way of the bomb-bay area i'll have to see. I have a small 2mm neodymium magnet in the rear of each door to help keep them closed.
Sean.
frank fearn
Postby frank fearn » June 8th, 2013, 9:03 pm
Heres one I've had a round for a while, ...Vailly Typhoon with a Quadra 100, Back on the board after the Dauntless ... :) :)
Frank
Aaron norman
Postby Aaron norman » June 9th, 2013, 7:24 pm
Getting there with the la7 not long now got all the litho plate bits done now to finish the office off before the front and back glazing gets glued on
Postby Phil Clark » June 15th, 2013, 9:09 pm
With surface detailing complete on the Corsair, last 2 major jobs before paint are renovating the retracts & fitting the tail wheels doors, plus cockpit interior & canopy.
Retracts were stripped, sand blasted, etch primed before being painted in Warbirdcolors US Sea Blue followed by a Klass Kote satin clear coat. A bit of time & effort but a big improvement over what I was supplied with.
