wanted DA prop drill
Postby richard armstrong » January 22nd, 2019, 3:08 pm
hi all i have to drill out several props for a DA50 Rear
has anyone got a prop drill guide they would like to sell or lend me
if you have please get in touch
ric
arthur barlow
Re: wanted DA prop drill
Postby arthur barlow » January 22nd, 2019, 8:31 pm
Ebay
Postby richard armstrong » January 22nd, 2019, 9:06 pm
MOST ARE dle on ebay
i looking for desert aircraft prop drill guide which is different but 5.2mm the dle is not the right one USA only
would like to borrow a DA guide rather than purchase if possible as a last resort i will buy one if have to & wait 6 weeks
Dave Wilshere
Postby Dave Wilshere » January 22nd, 2019, 9:15 pm
There is no difference DLE and DA use 5mm bolts and industry std hole centres. SECRAFT also make one that comes with 5.1mm drill
Postby richard armstrong » January 22nd, 2019, 9:26 pm
the difference is marginal with the layout
drilled 1 prop with dle drill guide line iup one hold and the DA holes where offset by 2 mm in the round
Postby Alan Cantwell 1131 » January 23rd, 2019, 7:20 am
Did you use a pillar drill, or a hand held, and did you put a bolt in the first hole drilled, to stop the jig moving, check the pitch circle diam with the prop washer, ,
Postby richard armstrong » January 23rd, 2019, 10:17 am
Alan Cantwell 1131 wrote:Did you use a pillar drill, or a hand held, and did you put a bolt in the first hole drilled, to stop the jig moving, check the pitch circle diam with the prop washer, ,
pillar drill, yes to all of the above
Dave Wilshere
Postby Dave Wilshere » January 23rd, 2019, 10:01 pm
Well maybe it was a 'poor'quality DLE jig as I have both genuine DA and DLE (from MacGregor) jigs and If I hold them together they are identical. I've sold lots of DLE type to DA customers with no comment.
Pillar drill is only OK if the bed is flat and 90 degrees to the drill. Props need to be supported on the hub to sit square, so props the TE of the blade is below the hub...
Postby richard armstrong » January 23rd, 2019, 10:43 pm
Dave Wilshere wrote:Well maybe it was a 'poor'quality DLE jig as I have both genuine DA and DLE (from MacGregor) jigs and If I hold them together they are identical. I've sold lots of DLE type to DA customers with no comment.
thanks dave i will reseat again the dle drill guide, the guide came direct from DLE so genuine, pillar drill was set perfect.
so i could only think is was me i have a busted prop i will try it again and see the da will line up with that
